Filter by Topic
Release
Popular Topics
- List all discussions
Error in parametric sweep simulation
Thread index | Previous thread | Next thread | Start a new discussion |
May 4, 2012 7:58pm UTC
I'm trying to run a joule heating simulation on a wire that is on a sapphire substrate. The wire has a hot spot in the middle and current is flowing threw it. My idea is to determine how long takes the system to thermally relax. I'm running a parametric sweep changing the thick of the wire, but when I compute the solution I get this error message:
Error in sweep: The following feature has encoutered a problem:
Extrude requires distances to be distinct.
Error in multiphysics compilation.
-Feature: Compile equations: Time dependent (sol1/st1)
-Error:Extrude requires distances to be distinct.
I've checked the busbar example in the tutorials and I can't find any differences between the example and my simulation.
I'm attaching the file I'm using
Emanuel
Reply | Reply with Quote | Send private message | Report Abuse
May 6, 2012 3:08am UTC in response to Emanuel Benatti
Re: Error in parametric sweep simulation
It sounds like your parameter change must have also effected the geometry or mesh in a manner that does not allow the embedded extrude to complete. Extrude will only occur in a geometry or mesh portion of the tree. You should be able to see the error in down the model tree. Look under geometry and/or mesh to find it.
May 8, 2012 4:36pm UTC in response to James D. Freels
Hi, thanks for the aswer
you were right mi problem is that the mesh gets coarser while my parametrer was changing. I manually adjusted the element size and the problem got solved.
Emanuel
Rules and guidelines
