Filter by Topic
Release
Popular Topics
- List all discussions
Solving same model in COMSOL and Matlab yields different results
Thread index | Previous thread | Next thread | Start a new discussion |
April 2, 2012 7:55pm UTC
Background:
I have a model created in COMSOL with mostly ellipsoids containing cylinders inside (different material), then joined with each other. Originally it gave me a hard time in meshing because I did not know how to "smooth out" the contact edges where the meshing gets extremely fine, so that it either threw meshing problem or divergent linear solution problem. With trial-and-error for a long time in every possible way, I simplified the model and perhaps marginally resolved the issue. At least, when I directly compute from COMSOL, it never complains.
Problem:
However, as I scripted it into Matlab because I needed to run different cases (where surface potential at some terminal differs), I got "divergence in linear solution," which threw me something like "java util exception."
What I did was simply save the working, solvable model as m-file, and called it from Matlab console, exactly same thing! But Matlab would not cooperate. And this error occurs only at some of the cases that I tried to run. e.g., case 1~4 passed, case 5, takes much longer than usual, then boom - error messages in red.
And also, even for the cases that did run, the solution was different from what was obtained by directly running from COMSOL. By "different," I mean off by more than 20% in some cases, which is way beyond the error margin that I am used to when running COMSOL.
Help:
Did anyone have similar experience? Different solution when running from COMSOL, than running through Matlab?
What differences may occur even though I simply save the COMSOL model as m-file?
Thank you.
Reply | Reply with Quote | Send private message | Report Abuse
April 2, 2012 8:45pm UTC in response to Rebecca Rosenbauer
Re: Solving same model in COMSOL and Matlab yields different results
I think the problem is here: "perhaps marginally resolved the issue".
Try to make a model that's stable and doesn't have convergence issues. If the problem "marginally" converges, you might sometimes even see difference from running it in COMSOL twice.
Upload your model and maybe we can come up with better meshing.
April 3, 2012 9:51pm UTC in response to Alexander Kuznetsov
here is the model. thanks a lot if you can take a look.
April 4, 2012 4:45pm UTC in response to Rebecca Rosenbauer
I can't open your model as I don't have AC/DC module. Can you copy your geometry to a model which uses only COMSOL multiphysics?
April 6, 2012 8:32am UTC in response to Alexander Kuznetsov
how about this time?
i do have a lot of difficulty with the meshing..
April 6, 2012 4:49pm UTC in response to Rebecca Rosenbauer
I found the problem. It's not meshing but your geometry. You have two edges (130 and 150) which are extremely short: 0.00037 nm. I don't think you meant to have them at all. Modify you geometry sequence to get rid of these edges, and everything should be fine. Other than that, your geometry is very easy to mesh. You can even use default meshing. Unfortunately I can't see you geometry sequence as you provided only .mphbin file.
April 9, 2012 8:42am UTC in response to Alexander Kuznetsov
Alex, thank you so much for looking at my file...
First of all, how did you find those two problems? I went into the selection list and went through all of them to double check for any unexpected small edges... and got rid of the two mentioned by "merging vertices," although it really isnt my original intention to create those two small parts and against the whole point of "automating creating the model."
However, the problem remains. i guess i really do not see any problem in meshing or else if running through COMSOL interface. but as soon as run it in Matlab, same old red errors occur.
I attached more error descriptions. Feel free to take a look.
P.S. the Matlab .m file needs AC/DC module to run. just thought it would be nice to see what code produced the error..
??? Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Failed to find a solution
(rethrown as com.comsol.util.exceptions.FlException)
The following feature has encountered a problem
Divergence of the linear iterations
Returned solution is not converged
- Feature: Stationary Solver 1 (sol1/s1)
- Error: Failed to find a solution.
Stack trace:
at com.comsol.solver.SolverOperation.addError(Unknown Source)
at com.comsol.solver.SolverOperation.execute(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl.a(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl.g(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl.runAll(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.comsol.clientserver.impl.JobImpl.run(Unknown Source)
at com.comsol.server.internal.a.a(Unknown Source)
at com.comsol.server.internal.a$a.a(Unknown Source)
at com.comsol.server.internal.a$a$a.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: Exception:
... 17 more
at com.comsol.model.clientserver.ClientManagerImpl.a(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl.runServerJob(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl$ak.a(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl$ak.execute(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl$e.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
... 3 more
... 17 more
Error in ==> finger at 249
model.sol('sol1').runAll;
April 9, 2012 5:24pm UTC in response to Rebecca Rosenbauer
Just looking at your mesh, I noticed that it was very fine around those points. I zoomed in and spotted two extra edges.
I'm not sure what's the problem with running your model with Matlab. Hard to tell without AC/DC module :) But looking at your .m file, why don't you do it through COMSOL interface using parametric sweep? It should be easy enough to implement.
Rules and guidelines
