Discussion Forum
Simulation of a superhydrophobic surface using level set method
Topics: Fluid Flow, CFD, 4.2, 4.3
Thread index  |  Previous thread  |  Next thread  |  Start a new discussion
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   4 Replies   Last post: July 6, 2012 9:45pm UTC
Nitant Gupta
Nitant Gupta
April 14, 2012 6:52pm UTC
I am a BE student of Mechanical engineering. My final year project is to simulate a superhydrophobic surface. I have been trying to do that for the past two-three months. After several failed approaches I decided to adopt the following method.
I tried to adapt the Rising Bubble model (using level set method) which is provided with COMSOL 4.2. First I made the whole model as per the steps described. This was simple and gave the said results. Then I decided to exchange the roles of the two fluids. So instead of the bubble of oil in the water layer, I made a droplet of water in the oil layer. I kept all the other settings as it is. Solving this model also gave appropriate results, i.e, the drop of water fell from the oil layer onto the water layer and mixed with it. Next I contemplated that if I simply replace the oil (material) with air I should obtain similar result. Replacing the material to air also meant that I had to change the surface tension parameter to liquid/gas from liquid/liquid. After doing this when I solved the model the solution failed to converge and reached a singularity. Just being curious I solved the model again, but this time I neglected the surface tension between the air/water interface. The solution did converge this time but my analysis remains incomplete without using the surface tension as it is an important parameter for simulating the contact angle on a hydrophobic surface. So the problem lies somewhere with the usage of the surface tension.
One more interesting observation was that if I make a model where a spherical droplet is touching a wetted wall (of some contact angle) in the two phase level set mode, and if I don't neglect the surface tension of the water/air interface, then the solution converges.However, when I run the animation, the size of the droplet keeps on decreasing and eventually it almost completely disappears.
I would really appreciate if someone can help me out with this.
Thank You!
Reply  |  Reply with Quote  |  Send private message  |  Report Abuse
Chloe Wu
Chloe Wu
July 6, 2012 2:06pm UTC in response to Nitant Gupta
Re: Simulation of a superhydrophobic surface using level set method
Hi Nitant,
I ran into the same problem as you did. I am wondering whether you have solved this problem?
Thank you!
Chloe
Nitant Gupta
Nitant Gupta
July 6, 2012 3:57pm UTC in response to Chloe Wu
Hi Chloe,
Sorry, I wasn't able to complete my simulation and still do not know what I can do to make it work. I suspect that it may be some inherent problem with COMSOL, as I have found several threads which discussed a similar problem. None of those threads came up with a solution, as far as I know. I guess someone from the COMSOL team should look into this and come up with some sort of tutorial or otherwise correct the problem itself.
Nitant
Ivar Kjelberg
Ivar Kjelberg
July 6, 2012 4:55pm UTC in response to Nitant Gupta
I cannot help, not really my "pot of tea" domain, but when noting else works, there is still "support" provided you have some maintenance contract, as for many software
Nagi Elabbasi
Nagi Elabbasi
Certified Consultant
Veryst Engineering
July 6, 2012 9:45pm UTC in response to Ivar Kjelberg
It is harder to get convergence with an air bubble compared to a water bubble in an oil medium. One reason is that surface tension exerts a pressure on the bubble. For incompressible water, that pressure will not result in any significant volume change. For air however, it may cause a severe transient if it is different from the initial pressure in the bubble. Therefore, try to adjust the initial pressure to reduce that transient.
Nagi Elabbasi
Veryst Engineering
Rules and guidelines
