Discussion Forum
Stress/vibration analysis
Thread index  |  Previous thread  |  Next thread  |  Start a new discussion
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: May 1, 2012 8:01pm UTC
Ulrika Lundholm
Ulrika Lundholm
April 27, 2012 6:26am UTC
Hey,
I want to do a stress analysis on a structure exposed to vibrations in the range of 100-2.5k Hz
I’ve made an attempt by using the Frequency-Domain Modal study in the Solid Mechanics interface.
I’ve tried using different frequency sweeps but don’t get any results (0 displacement for all frequencies), although I’ve managed to run the Egienfrecuency study successfully.
I’ve attached my model in this mail. I would be very grateful if someone could give me some feedback on my model.
/Ulrika
Attachments:   Stress_frequency loads.mph
Reply  |  Reply with Quote  |  Send private message  |  Report Abuse
Ivar Kjelberg
Ivar Kjelberg
April 27, 2012 1:31pm UTC in response to Ulrika Lundholm
Re: Stress/vibration analysis
A frequency domain analysis applies a Force load (that you have forgotten to define) as an amplitude mutliplied by a constant sinus type excitation at a frequency range you define.
The second effect is that you have resonaces around 25 kHz and you are plotting the respons around 100 Hz, you will see nothing so far away from your resonance.
I would propose:
1) perform a eigenfrequency to get the modes
2) start with frequency domain (then later go to frequency - modal) for a frequency range ot +/- 5% around your first resonance
3) define a load, i.e. a body gravity load Fy=g_const*solid.rho
then run
Another point to consider: damping, without any damping the resoance are so sharp that often COMSOL either skip then or fail to pass the resonance
To get back to your frequency-domain modal :
Do not forget: !!!!
you need to right click the body or boundary load and add a "Harmonic perturbation" tick this will add the "tilda" on the icon and your load will now be correctly set up .
Attachments:   FreRespModaltst1.mph
Ulrika Lundholm
Ulrika Lundholm
May 1, 2012 8:01pm UTC in response to Ivar Kjelberg
Thank you very much Ivar!
I think I get it now =)
Rules and guidelines
