Discussion Forum
Conjugate, non-isothermal u-pipe, time-dependent study
Thread index  |  Previous thread  |  Next thread  |  Start a new discussion
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   2 Replies   Last post: May 14, 2012 11:31am UTC
He Qi
He Qi
May 1, 2012 9:04pm UTC
I wanted to simulate the heat transfer of fluid in a u-pipe. However, I'm really confused about which module and model should I use?
Initially what I wanted to do is to choose the heat transfer in porous media modulue, however, I found difficulties of solving the problem of directing the fluid from vertical pipe into u-shaped corner by defining a velocity. Based on my shallow experience with Comsol so far, it seems that this modulus only allows the fixed velocity vector to be defined at the input stage, and I found it difficult to resolve for the model.
I have also tried to use the conjugate heat transfer as well as non-isothermal flow... then I started to get more confused because my analysis has to be carried in time-depenent study. Would anyone give me some advices?
Thanks for your advice in advance!
Reply  |  Reply with Quote  |  Send private message  |  Report Abuse
Steven Chiuta
Steven Chiuta
May 14, 2012 9:56am UTC in response to He Qi
Re: Conjugate, non-isothermal u-pipe, time-dependent study
I am alos new to Comsol but i would suggest that you start simple. Just forget about using the conjugate heat transfer application mode and try to do it stepwise using simpler physics that when coupled approximate conjugate heat transfer. For example, you could start by solving the fluid flow alone then couple this to heat transfer or reaction and see what you get.
Ivar Kjelberg
Ivar Kjelberg
May 14, 2012 11:31am UTC in response to Steven Chiuta
Indeed I would say that is a wise advice, but do not foret that, depening on your model, you do not always who is "master" and who is "slave" between flow and heat. So ending up with a fully coupled and pre-cooked Conjugated Heat Flow model is good practice too
Rules and guidelines
