Discussion Forum
shear stress in microchannel
Thread index  |  Previous thread  |  Next thread  |  Start a new discussion
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   6 Replies   Last post: June 6, 2012 4:47am UTC
Cindy Duong
Cindy Duong
May 8, 2012 4:50am UTC
I am clueless as to how to start the post-process data analysis to get the spatial distribution of shear stress of a micro channel. I have read the few discussion threads but it involves exporting the slice 3D plot of the velocity and then do the calculation of shear stress in Matlab. I would appreciated it if someone can either tell me (a) what Matlab code or equation you used to solve for shear stress from the velocity profile slice or (b) a way to get Comsol to compute shear stress for me and graph it (a much easier way for a newbie like me).
Thank you so much!
Reply  |  Reply with Quote  |  Send private message  |  Report Abuse
Ivar Kjelberg
Ivar Kjelberg
May 8, 2012 5:31am UTC in response to Cindy Duong
Re: shear stress in microchannel
Are you sure you do not have enough COMSOl variables already defined to extract the shear stress directly in the GUI ?
Cindy Duong
Cindy Duong
May 8, 2012 4:28pm UTC in response to Ivar Kjelberg
Correct me if I am wrong, the direction of my flow velocity is in the y-axis and if I want to calculate the shear stress for an xy plane slice along a z-axis coordinate, then I input the expression "spf.mu*(vx+uy)" with spf.mu is the dynamic viscosity to give shear stress in Pa?
Ivar Kjelberg
Ivar Kjelberg
May 8, 2012 6:34pm UTC in response to Cindy Duong
well within a minus sign that is the COMSOL internal stress tensor variable:
spf.K_stress_tensorxy
check your expressions, so I would say its not far away ;)
Cindy Duong
Cindy Duong
May 8, 2012 9:52pm UTC in response to Ivar Kjelberg
i don't quite understand what you mean by the previous statement because when I enter that tensor variable expression I get the same results as before.
Gautier Picot
Gautier Picot
June 6, 2012 4:04am UTC in response to Cindy Duong
Hi Cindy,
I am interested in the same problem, have you found an answer?
Thanks in advance,
Gautier
Ivar Kjelberg
Ivar Kjelberg
June 6, 2012 4:47am UTC in response to Cindy Duong
my comment was just to remind you about all the predefined internal variables of COMSOL, unfortunately I do not know of any exhaustive list, but you can find them in the pull down menus of the Derived Variables, (or with the CNTRL Space) and in the equation view nodes
Rules and guidelines
