Non-isothermal flow problem
I was recently working on a plasma arc stationary simulation. The simulation contains two modules: non-isothermal flow and magnetic electric field.
The simulation is highly non-linear, the plasma is heated by electric field, and the flow has a volume force thus magnetic force.
The plasma property(density,electric conductivity ,dynamic viscosity, thermal conductivity,heat capacity at constant pressure)is the function of temperature.
I first use the automatic highly nonlinear damping solving. Comsol can not get a converged results . So I go on the iteration using a constant damping factor(0.01). After several steps, the results flew away, negative temperature appears.
I first thought it was the problem of mesh quality.But after trying changes in mesh, I still cannot solve it. When the volume force is neglected, comsol can get a converged results(first using automatic damping, then go on the iteration with a series of increasing constant damping factor: 0.1-1)
Who can help me?
0 Replies Last Post 05.05.2011, 22:36 GMT-4
Hello chen tang
