Failed to evaluate variable.
I was trying to run an impedance calculation on a square copper coil in air. I am using a trial version of comsol. It gives me the following error:
variable: mod1.emw.ahPortx
Geometry: 1
Boundary: 33
failure to evaluate expression
expression ((((mod1.emw.ahPortx*mod1.tEx)+ (mode1.tEy*mod1.emw.ahPorty))+(mod1.emw.ahPortz*mod1.tEz))/mod1.emw.wPort)
Failure to evaluate expression
Expression: mod1.emw.intlport1(((((mod1.emw.ahPortx*mod1.tEx)+(mod1.tEy*mod1.emw.ahPorty))+(mod1.emw.ahPortz*mod1.tEz))/mod1.emw.wPort))
variable mod1.emw.Vport_1
defined as :mod1.emw.intlport1(((((mod1.emw.ahPortx*mod1.tEx)+(mod1.tEy*mod1.emw.ahPorty))+(mod1.emw.ahPortz*mod1.tEz))/mod1.emw.wPort))
variable: mod1.emw.Zport_1
defined as: (mod1.emw.Vpodt_1/mod1.emw.Iport_1)
failed to evaluate expression.
Expression: abs(mod1.emw.Zport_1)
Failed to evaluate expression
Expressiong: abs(mod1.emw.Zport_1)
Plot:glob1(Global)
2 Replies Last Post 21.06.2011, 09:51 GMT-4
Posted: 1 decade ago 21.06.2011, 04:28 GMT-4
I had similar problems with uniform lumped ports. It worked after I changed it to user defined ports specifiying height and width of the port. I don't know why the uniform port didn't work and also COMSOL support couldn't help.
I am using 4.1.
Cheers
Edgar
Hi, I had similar problems with uniform lumped ports. It worked after I changed it to user defined ports specifiying height and width of the port. I don't know why the uniform port didn't work and also COMSOL support couldn't help. I am using 4.1. Cheers Edgar
Posted: 1 decade ago 21.06.2011, 09:51 GMT-4
Thanks for the suggestion. Will surely look into that.
From what i see from the other threads, it also depends on luck?
For some it works while for the others it does not.
Any idea on that?
Thanks for the suggestion. Will surely look into that. From what i see from the other threads, it also depends on luck? For some it works while for the others it does not. Any idea on that?
