Question Regarding 3D Geometry
I have a question regarding a 3d geometry. I want to draw the following geometry:
1) Draw a sphere (3D) ... I can draw it.
2) Drawing small spheres or non-spherical geometries (of same shape and size at equidistant like aray) around the big sphere (which was drawn in first step).
For understanding purpose, please consider the picture (attached) in 3D.
Is it possible to draw these small object around an object with some tool available in Comsol. How can I draw it..
Any suggestion/comment will highly be appreciated.
Thanks in advance.
Best Regards
Qasim
2 Replies Last Post 27.09.2011, 07:56 GMT-4
Posted: 1 decade ago 27.09.2011, 07:48 GMT-4
In V4 what if you try the "rotate command" on the small circle and define a "range" see the image
Hi In V4 what if you try the "rotate command" on the small circle and define a "range" see the image -- Good luck Ivar
Posted: 1 decade ago 27.09.2011, 07:56 GMT-4
Dear Ivar,
Thanks a lot. It worked.
Best Regards
Qasim
Dear Ivar, Thanks a lot. It worked. Best Regards Qasim
