pulse generation
I am new to comsol and I want to generate a single pulse of 0.7 v of 20us . this will act as a voltage to a structure and the structure will get heated up. Now my point is to see how fast the structure cools down.
I have no idea how to do this. what I did is defined a rectangle function with lower limit as 20 us and upper limit as 40 us and then i try to use 0.7*rect1(t1) as a input voltage. I tried to follow the suggestion in the other threads but could not understand. Can anybody help me? BTW I am using V4.2a.
3 Replies Last Post 30.04.2012, 13:57 GMT-4
Posted: 1 decade ago 26.04.2012, 14:34 GMT-4
the rect() or pulse function, just as he step function has a rise time defined in the dvanced tab (normally "closed") you need to adapt this parameter too when you have such short pulses, do not make it too steep, or then at least define enough time stepping (or parameter stepping) points in the solver definition to catch the rise time (I would say at least 5 step during the rise and fall time. If you are doing time dependent studies, as I understand, check also the solver stepping settings and use an "intermediate" and NOT automatic stepping scheme, as you have a rise and a fall time here. Then if the default BDF does not converge, you could also try the Gen-alpha solver, it's sometimes more stable, but often somewhat slower, all depends ...
Hi the rect() or pulse function, just as he step function has a rise time defined in the dvanced tab (normally "closed") you need to adapt this parameter too when you have such short pulses, do not make it too steep, or then at least define enough time stepping (or parameter stepping) points in the solver definition to catch the rise time (I would say at least 5 step during the rise and fall time. If you are doing time dependent studies, as I understand, check also the solver stepping settings and use an "intermediate" and NOT automatic stepping scheme, as you have a rise and a fall time here. Then if the default BDF does not converge, you could also try the Gen-alpha solver, it's sometimes more stable, but often somewhat slower, all depends ... -- Good luck Ivar
Posted: 1 decade ago 30.04.2012, 03:35 GMT-4
Hi Ivar,
Thanks a lot for your reply. I started reading the user's guide after your reply but could not find any advanced tab. how can I activate this advanced tab ?
Hi Ivar, Thanks a lot for your reply. I started reading the user's guide after your reply but could not find any advanced tab. how can I activate this advanced tab ?
Posted: 1 decade ago 30.04.2012, 13:57 GMT-4
my fault it's not the advanced it's the "smoothing" tab (I get also confused, and I'm not always behind my WS ;)
You are right that many of the "advanced" tabs are hidden,by default you must turn them on from the the Options Preferences View tab
Hi my fault it's not the advanced it's the "smoothing" tab (I get also confused, and I'm not always behind my WS ;) You are right that many of the "advanced" tabs are hidden,by default you must turn them on from the the Options Preferences View tab -- Good luck Ivar
