How to divide a solution by another solution
Greetings all, I am solving Darcy's Law and Solute Transport in a 2D rectangular model domain (using Comsol 4.2). I would like to normalize the solution by a known solution. This would basically entail dividing my solution by another solution.
More detailed explanation:
I am calculating groundwater solute concentrations using the solute transport model for 2 scenarios: one is an isotropic hydraulic conductivity (Darcy's Law), and the second is an anisotropic hydraulic conductivity. I would like to divide the anisotropic results by the isotropic results for visualization on a surface plot. Can anybody provide an explanation for how to divide a solution by another solution?
Thanks for your help!
E.J.E.H.
4 Replies Last Post 04.05.2012, 15:19 GMT-4
Posted: 1 decade ago 02.05.2012, 16:31 GMT-4
It can be automated in 'Comsol with Matlab':
1. Run a first loop of your base case
2. Extract data from your base case with mpheval
3. Run a second loop of your modified case
4. Extract data again with mpheval, of course you assign different names to extracted variables. If the mesh hasn't changed, all dependent variables values will be stored in the same order.
5. divide the 2 sets of data as you wish
For the looping and extracting procedure, look here : www.comsol.com/community/forums/general/thread/8840/
It can be automated in 'Comsol with Matlab': 1. Run a first loop of your base case 2. Extract data from your base case with mpheval 3. Run a second loop of your modified case 4. Extract data again with mpheval, of course you assign different names to extracted variables. If the mesh hasn't changed, all dependent variables values will be stored in the same order. 5. divide the 2 sets of data as you wish For the looping and extracting procedure, look here : http://www.comsol.com/community/forums/general/thread/8840/
Posted: 1 decade ago 04.05.2012, 15:05 GMT-4
Thanks, but I am hoping to find a way to do this in the COMSOL GUI. It seems like if you have two study's it shouldn't be difficult to do some simple algebra of the two solutions...
Posted: 1 decade ago 04.05.2012, 15:18 GMT-4
Once I have a solution in MATLAB and have exported it as a txt, how do I import it into COMSOL for visualization? I do not have the Comsol-Matlab license, so I have to do things piecemeal...
Posted: 1 decade ago 04.05.2012, 15:19 GMT-4
In Results-Data Sets you can choose Join to combine two solutions. There are options to add, subtract or multiply the solutions. Unfortunately, you can't divide them. But maybe difference will work for you?
