Mathematical Particle tracing - resintence force
Hi!
I'm trying to compute some trajectories using Comsol Math. Particle Tracing in the Newtonian formulation for some force which is of the form:
F=F1+F2
where F1 is proportional with the dielectrophoresis force
and F2 is a drag force proportional with the velocity.
my question is: haw do I introduce a time derivative in Math PT? to simulate a force proportional with velocity or haw do I introduce a velocity term in the force?
I've tried something like F1=2*d(x,t) but seams to not work.
Can anyone please help me?
Ciprian
2 Replies Last Post 24.10.2012, 13:37 GMT-4
Posted: 1 decade ago 24.10.2012, 13:26 GMT-4
by default, if F1 is a dependent variable, normally COMSOL defines the time derivative as F1t and 2nd as F1tt
Check the equations
Hi by default, if F1 is a dependent variable, normally COMSOL defines the time derivative as F1t and 2nd as F1tt Check the equations -- Good luck Ivar
Daniel Smith COMSOL Employee
Posted: 1 decade ago 24.10.2012, 13:37 GMT-4
Hi, in the "Particle Tracing for Fluid Flow" interface, available in the "Fluid Flow" section of the "Add Physics" wizard there are predefined features available for both the dielectrophoretic and drag forces. I recommend you use this interface, instead of the "Mathematical Particle Tracing" interface.
