Problem with insulation...
While using the Non-Isothermal Flow (nitf) and Heat Transfer in Solids (ht), I am facing problem with insulation being allocated to the faces that are not insulated. I suppose that I am not getting correct results because of this issue. Can anybody help me how to correct it? Actually, my model does not need any insulation.
3 Replies Last Post 04.02.2013, 10:03 GMT-5
Posted: 1 decade ago 04.02.2013, 01:47 GMT-5
Isolation goes, by default, on all faces not given other overriding BC conditions, so I would rather say Check carefully your BC. Do not forget that in multi physics you need to set all BC for ALL dependent variables, so sometimes you need several symmetries or other conditions
Hi Isolation goes, by default, on all faces not given other overriding BC conditions, so I would rather say Check carefully your BC. Do not forget that in multi physics you need to set all BC for ALL dependent variables, so sometimes you need several symmetries or other conditions -- Good luck Ivar
Posted: 1 decade ago 04.02.2013, 03:46 GMT-5
Sir,
I have selected some faces of interaction between fluid and solid for heat flux and it is showing those faces as overridden in the thermal insulation tab. Is the thermal insulation de-activated for those faces or any error has occurred??
[QUOTE] Hi Isolation goes, by default, on all faces not given other overriding BC conditions, so I would rather say Check carefully your BC. Do not forget that in multi physics you need to set all BC for ALL dependent variables, so sometimes you need several symmetries or other conditions -- Good luck Ivar [/QUOTE] Sir, I have selected some faces of interaction between fluid and solid for heat flux and it is showing those faces as overridden in the thermal insulation tab. Is the thermal insulation de-activated for those faces or any error has occurred??
Posted: 1 decade ago 04.02.2013, 10:03 GMT-5
read the doc on contributive and exclusive BC's for your physics. The first nodes, with a "D" are defaults that COMSOL set-up to have a coherent initial situation. while you add new BC's some interfere with the ones above, some override(the one latest further down has the precedence, except if you explicitely "disable it") , other contributes (add in so both are bringing something)
Hi read the doc on contributive and exclusive BC's for your physics. The first nodes, with a "D" are defaults that COMSOL set-up to have a coherent initial situation. while you add new BC's some interfere with the ones above, some override(the one latest further down has the precedence, except if you explicitely "disable it") , other contributes (add in so both are bringing something) -- Good luck Ivar
