COMSOL shortcut buttons
Is there a shortcut button for 'solve', 'cancel solve', 'interupt solve'?
3 Replies Last Post 02.06.2022, 23:39 GMT-4
Magnus Ringh COMSOL Employee
Posted: 2 years ago 31.05.2022, 09:16 GMT-4
Hi Carl,
To compute an entire study, press F8. To compute a selected study step, press F7. Currently there is no shortcut key for canceling a solution process, but we will look into that for a future version. For now, you can use the Cancel button in the lower-right corner of the COMSOL Desktop or any of the Stop buttons in the Progress window.
Magnus
Hi Carl, To compute an entire study, press `F8`. To compute a selected study step, press `F7`. Currently there is no shortcut key for canceling a solution process, but we will look into that for a future version. For now, you can use the **Cancel** button in the lower-right corner of the COMSOL Desktop or any of the **Stop** buttons in the **Progress** window. Best regards, Magnus
Posted: 2 years ago 31.05.2022, 13:39 GMT-4
Hi Carl, Magnus,
it should be added that by using the 'cancel' button you typically loose the so far calculated solution, e.g. in a time dependent study. Using the 'stop' buttons preserves the solution.
In an application there is no option to 'stop' the solution in a controlled way, you always loose the complete solution by cancelling. @Magnus: is anything in view to allow a controlled stop in applications?
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Carl, Magnus, it should be added that by using the 'cancel' button you typically loose the so far calculated solution, e.g. in a time dependent study. Using the 'stop' buttons preserves the solution. In an application there is no option to 'stop' the solution in a controlled way, you always loose the complete solution by cancelling. @Magnus: is anything in view to allow a controlled stop in applications? Cheers Edgar
Posted: 2 years ago 02.06.2022, 23:39 GMT-4
Hi Magnus, Edgar, thanks so much for your help! Once a solution is stopped (a) and continued (b), probe plots during (a) disappear. Is there a solution to this?
