04.11.2010, 07:41 MEZ
Hi Matthias
first are you in 3.5 or 4 ?, in 4 you have two ways of parametrising:
a) for a fixed geometry but with a variable that actson some physics: use the i.e. stationary continuation/extend tab in the Solver subnode
b) to vary the geoemtry, add an explicit Parametric to your solver sequence.
Only the latter will loop around all your parameter hence rebuild geoemrty and meshing if required
This might be (part of?) your issue
Hi Matthias
05.11.2010, 07:05 MEZ
Him
yes, I am using 4.0a. I guess the problem of the optimizer not changing anything during its runs (and therefore not detecting any gradients) is due to a second problem, that is the obvious fact that parameter changes are not always propagated correctly.
Regards
Matthias
Him
Regards
Matthias
05.11.2010, 14:00 MEZ
yes you are the Nth today noticing that the lower subnodes are not updating in 4.0 and 4.0a, I see its fixed in 4.1 ;)
in the previous versions you must update the fields in BOTH node and subnode
10.11.2010, 07:23 MEZ
Actually, support has said something slightly different: I had a parameter that had not had any direct use in a geometry, but was used to calculate other parameters only. This is not properly detected, and the parameter is taken to be not relevant. The workaround is to make the geometry use this parameter as well, e.g. by adding "N-N" (N was my parameter) somewhere as a geometric parameter.
10.11.2010, 08:40 MEZ
Sorry for have missed that; interesting, indeed there are many cases to consider, and COMSOL cannot understand all our wills ;)
