                                04.12.2010, 07:45 GMT-5
from what I remembered, only one (without passing through matlab) but you could have several parameter for the sae sweep, check the doc
of the type
param1 param2 ...
1 1.1 2 2.2 3 3.3
giving
param1  = {1 2 3}
param2 = {1. 2.2 3.3}
of the type
param1 param2 ...
1 1.1 2 2.2 3 3.3
giving
param1  = {1 2 3}
                                04.12.2010, 09:56 GMT-5
I knew this method ;but by using this method only value the first parameter changes the second is fake
                                04.12.2010, 10:24 GMT-5
                                                    Mohammadreza,
I used this method and it works properly. You might want to check it in a simple place like expressions and plot it Vs a parameter.
Again, if your parameters are vectors say {a} and {b}
So in GUI, they are
a1 b1 a2 b2 a3 b3...etc
Good luck,
Stephan
                            Mohammadreza,
So in GUI, they are
Good luck,
Stephan
                                05.12.2010, 03:20 GMT-5
there is one limitation: the first parameter must always be monotonously increasing (or decrasing)
