Evaluating Global Expressions in MATLAB
I have set up a series of Global Expressions in my model through the COMSOL GUI. I now solve the model through MATLAB and would like to evaluate the Global expressions.
The problem is I cannot find the function to do this? From the documentation it would seem postglobaleval is my best bet:
>> postglobaleval(femt,'iOut')
??? Error using ==> postglobaleval at 70
Expression must be a cell array.
I have also tried
>> posteval(femt,'iOut')
ans =
p: [3x28840 double]
t: [4x38934 double]
q: [8x0 double]
d: [1x28840 double]
elind: [1x28840 double]
but then I am unsure of where to go from here? I have read this, but it confuses me greatly
The output is post data, a structure with fields p, t, q, d, and elind. The field p contains node point coordinate information. The number of rows in p is the number of space dimensions. The field t contains the indices to columns in p of a simplex mesh (each column in t represents a simplex). The field q contains the indices to columns in p of a quadrilateral mesh, with each column in q representing a quadrilateral. The field d contains data values. The columns in d correspond to node point coordinates in columns in p.
Any assistance would be greatly appreciated.
Tom
4 Replies Last Post 21.07.2014, 09:34 MESZ
Posted: 2 decades ago 29.10.2009, 13:41 MEZ
easiest to sort out these cases (I always restart from scratch) is to start with a simple beam and only mesh it with very few elemnts 2-8 so you can easily track them in your head and on papaer with a simple analytical case.
then you can understand the use and identification of the p, d, t, q
I beleive I remeber (I do not have my manuals here), that the t are the tetrahedral elements, the q the quad (often you have only one of the two types), p are the node coordinates, and d the data
So and if I have it right "t" is the "indexes" of nodes "p" making up the thets and "q" the indexes making up the quad elements (careful with orientation to not invert them). And d are the data values at the nodes "p"
Pls check this carefully, because I'm recording from what I remember and cannotcheck.
hope this helps
Hi easiest to sort out these cases (I always restart from scratch) is to start with a simple beam and only mesh it with very few elemnts 2-8 so you can easily track them in your head and on papaer with a simple analytical case. then you can understand the use and identification of the p, d, t, q I beleive I remeber (I do not have my manuals here), that the t are the tetrahedral elements, the q the quad (often you have only one of the two types), p are the node coordinates, and d the data So and if I have it right "t" is the "indexes" of nodes "p" making up the thets and "q" the indexes making up the quad elements (careful with orientation to not invert them). And d are the data values at the nodes "p" Pls check this carefully, because I'm recording from what I remember and cannotcheck. hope this helps Good luck Ivar
Posted: 2 decades ago 29.10.2009, 16:23 MEZ
Hi Ivar,
I have found the solution:
iout = postglobaleval(fem,{'iOut'})
which returns:
iout =
x: [101x1 double]
y: [101x1 double]
legend: {'iOut'}
I may then access the expression at a single data point with:
iout.y(90)
or plot the results with:
plot(iout.x,iout.y)
Tom
Hi Ivar, I have found the solution: [quote] iout = postglobaleval(fem,{'iOut'}) [/quote] which returns: [quote] iout = x: [101x1 double] y: [101x1 double] legend: {'iOut'} [/quote] I may then access the expression at a single data point with: [quote] iout.y(90) [/quote] or plot the results with: [quote] plot(iout.x,iout.y) [/quote] Regards, Tom
Posted: 2 decades ago 30.10.2009, 07:42 MEZ
Hi Tom
As often, it's "evident" once you have found the error, it was almost written litterally, I searched for a comsol explanation but it was a programming cast error, I should too have seen it too, willdo better next time ;)
Thanks for the reply
Hi Tom As often, it's "evident" once you have found the error, it was almost written litterally, I searched for a comsol explanation but it was a programming cast error, I should too have seen it too, willdo better next time ;) Thanks for the reply Ivar
Posted: 1 decade ago 21.07.2014, 09:34 MESZ
I solved my problem thanks to this thread.
It was a big help for me.
Thank you again for discussion.
- Seong Jae
I solved my problem thanks to this thread. It was a big help for me. Thank you again for discussion. - Seong Jae
