How to transfer "eigenfrequency" from eigenfrequency to frequency domain step
Posted 03.04.2017, 13:21 GMT-4 Acoustics & Vibrations, Structural Mechanics Version 5.1 2 Replies
I am trying to simulate acoustic levitation, including both mechanics and acoustics. Simulation consists of two parts - structural mechanics and piezoelectrics, where eigenfrequency step is used to get resonance frequency of whole ultrasonic transducer. Next, frequency domain step is used with acoustics module, to get pressure and velocity field of gas with respect to computed mechanic displacement field as input.
When I run this by myself, eg run Step1 (mechanics and piezoelectrics active), ctrl+c resulting eigenfrequency, switch to Step2 (acoustics active), ctrl+v frequency, run, everything is fine. However, I am unable to setup Comsol to transfer computed eigenfrequency from Step1 to Step2 by itself. It would be useful, because with that, I would be able to use optimization and next features...
I can't use Frequency domain modal (which - if i got it right - is supposed to handle this case), because I need to separate these two steps as described. And I can probably use LiveLink with Matlab and handle it by myself, but I think it shouldn't be necessary.
Thank you,
Petr Barton
Thank you,
Petr Barton
2 Replies Last Post 07.04.2017, 14:16 GMT-4
