Livelink for Pro-Engineer error: ... PRO_COMM_MSG_EXE ...
Hi All,
I have installed live link for Pro-Engineer 4.0.
On the Comsol model builder right click and Livelink for Pro-Engineer. As i click on synchronize, an error report was appear:
Failed to connect to Pro/ENGINEER.
Please check the PRO_COMM_MSG_EXE environment variable is set correctly before launching COMSOL.
please tell me how to repair this failure.
thanks
regards
4 Replies Last Post 13.10.2016, 05:12 MESZ
Posted: 1 decade ago 08.04.2011, 20:44 MESZ
You need to go My Computer>Right Click>Properties>Advanced System Settings then
Environment Variables and add PRO_COMM_MSG.EXE as variable name and path of file as variable value
which is like C:\Program Files (x86)\proeWildfire 4.0\i486_nt\obj\pro_comm_msg.exe
Place it in system variable section and do a restart.
Unfortunately. I found your message while I was having the same problem. This did not help me but I hope it solves your problem..
System
Hi All,
thanks
regards
Hi, You need to go My Computer>Right Click>Properties>Advanced System Settings then Environment Variables and add PRO_COMM_MSG.EXE as variable name and path of file as variable value which is like C:\Program Files (x86)\proeWildfire 4.0\i486_nt\obj\pro_comm_msg.exe Place it in system variable section and do a restart. Unfortunately. I found your message while I was having the same problem. This did not help me but I hope it solves your problem.. System [QUOTE] Hi All, I have installed live link for Pro-Engineer 4.0. On the Comsol model builder right click and Livelink for Pro-Engineer. As i click on synchronize, an error report was appear: Failed to connect to Pro/ENGINEER. Please check the PRO_COMM_MSG_EXE environment variable is set correctly before launching COMSOL. please tell me how to repair this failure. thanks regards [/QUOTE]
Posted: 1 decade ago 27.06.2013, 14:41 MESZ
When you add Environment Variables do not add PRO_COMM_MSG.EXE but PRO_COMM_MSG_EXE this solved it for me.
Posted: 9 years ago 07.12.2015, 05:37 MEZ
hey you said " path of file as variable value
which is like C:\Program Files (x86)\proeWildfire 4.0\i486_nt\obj\pro_comm_msg.exe"
please explain how to find this variable value
hey you said " path of file as variable value which is like C:\Program Files (x86)\proeWildfire 4.0\i486_nt\obj\pro_comm_msg.exe" please explain how to find this variable value
Posted: 9 years ago 13.10.2016, 05:12 MESZ
hi,
have you solved this promblem at last? I have done everything as they said, but it didn't work.
Could you please tell me how do you solve it.
Thank you~~~
hi, have you solved this promblem at last? I have done everything as they said, but it didn't work. Could you please tell me how do you solve it. Thank you~~~
