How to measure power in COMSOL wave optics?
Hi all,
I'm wondering if anyone knows how to measure the power in COMSOL wave optics, for example the power coming out of from a line in a case of 2D simulation.
I've seen in a video on Youtube where the lecturer integrated the 'sqrt(ewfd.Poavx^2+ewfd.Poavy^2+ewfd.Poavz^2)' value along a line to represent the power. However, the software also provides a value called 'ewfd.nPoav'. I'm confused which one is the correct one to use since they sometimes actually give different results. I tried to test these two methods by checking, for example, the power at the input side and output side of a slab waveguide, but the power I measured at the input and the output do not agree with each other. Does anyone know the correct way to measure the power? Many thanks in advance.
1 Reply Last Post 20.10.2017, 03:44 MESZ
Posted: 8 years ago 20.10.2017, 03:44 MESZ
The ewfd.nPoav variable refers to the component of the average power that is "normal" to (aka, perpendicular to) a particular surface. It is thus not the same as the "norm" or magnitude, of the vector, in general. This is why you get a different answer from using the longer expression.
