splitting 3D problem into 2D
Hi, i am dealing with a large 3D problem of heat trasnfer and fluid flow. i want to split it into maybe 100 2D planes instead startgin from the first plane at ground surface. 2nd place about 20cm depper and so on. i can assume between the 2 planes temperature changes linearly. the question is that i need to somehow use the temperature distribution of my first plane into the second one (20 cm deeper). but not the last step results only, but i need to somehow use the temperature and pressure distribution from first plane varygin by time into the second one for example as an out of plane heat trasnfer from the plane above. it this doable? im sorry i understand if i have given a complicated explanation on this problem.
Regards, Asal
0 Replies Last Post 11.02.2018, 17:05 MEZ
Hello Asal Bidarmaghz
