Splitting into several domains
The below post is related to an archived discussion
I have a rectangular geometry with several channels, which water is supposed to flow through. Other than the channels, the rest of the geometry should be Aluminium. The geometry is imported from SolidWorks as a STEP file.
I am trying to investigate the heat transferred and the flow of the water but I encounter the problem when the geometry is imported, it becomes one whole domain, thus creating problem when I'm trying to assign water as material inside the channels.
My question is, how can I separate the channels into a different domain? I tried 'split' operation but did not seem to work.
2 Replies Last Post 19.04.2018, 08:59 MESZ
Yara Soares COMSOL Employee
Posted: 8 years ago 20.02.2018, 15:54 MEZ
Dear Pei Yi,
Thank you for submitting your question on this forum. However I would like to advise you to address it to support@comsol.com.
Kind regards,
Yara Soares
COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212
www.comsol.nl | eveline.jacobse@comsol.com
Dear Pei Yi, Thank you for submitting your question on this forum. However I would like to advise you to address it to support@comsol.com. Kind regards, Yara Soares ---------------------------------------------------------------------- COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212 www.comsol.nl | eveline.jacobse@comsol.com ----------------------------------------------------------------------
Posted: 7 years ago 19.04.2018, 08:59 MESZ
Turn out I just did not cap the faces of the channels.
