How to rotate a 2D plot made based a general type plane
I build a 3D model with which I want to make a vertical plane and it is not parallel to x or y axis, so I made this plane with three points using general plane type. However, the 2D plots made with this plane has z axis horizontally, is there anyway to rotate these 2D plots?
Shuhan
1 Reply Last Post 18.04.2018, 14:11 MESZ
Posted: 7 years ago 18.04.2018, 14:11 MESZ
I've just figured out. It can be rotated by change the order of point 1,2,3 when creat the plane, the bottom left point should be point 1, and bottom right point should be point 2.
