03.05.2011, 15:07 MESZ
Hi Saeid,
Try looking in the COMSOL LiveLink™ for MATLAB® User's Guide at the following commands to see if they do what you want:
1. mpheval
2. mphinterp
The first one pulls results at specified node points, the second one pulls results at arbitrary points.
This is the code I use for extracting the electric field at specified coordinates:
fieldMap(:,1:3) = coordinates;
[fieldMap(:,4),fieldMap(:,5),fieldMap(:,6)] = mphinterp(model, {'es.Ex','es.Ey','es.Ez'}, 'coord', coordinates.');
This comes from a function with is available on launchpad at
bazaar.launchpad.net/~mattachu/modelrfq/trunk/view/head:/Matlab/ComsolInterface/getFieldMap.m
Hope it helps!
matt
Hi Saeid,
1. mpheval
2. mphinterp
This comes from a function with is available on launchpad at http://bazaar.launchpad.net/~mattachu/modelrfq/trunk/view/head:/Matlab/ComsolInterface/getFieldMap.m
Hope it helps!
matt
08.05.2011, 09:25 MESZ
Hi mattachu,
Thanks for you reply.
I use Comsol 3.5a and Matlab 2008. I can connect this two programs, but when I save my model in .m format and run it in Matlab, I have not obtained any results!!!
I am not sure that if it is because of Comsol and Matlab programs or I have any other problems in my modeling?! I have attached my mfile to this message, Would you please check it?!
Input and outputs of this mfile should be 40*1 vectors.
Saeid
Hi mattachu,
Saeid
09.05.2011, 09:06 MESZ
Ah, I'm sorry then, I only have experience with extracting data from Comsol 4. Unfortunately the functions I mentioned above are only available in later versions of Comsol. When I used to use Comsol 3.5a I just extracted data manually rather than using Matlab.
Hopefully someone else will have the knowledge to help you.
[QUOTE]
[/QUOTE]
