Apply physics to each object (Application builder)
Hello, I'm generating a vector of circle objects programmatically (2D), this works well, but I want to apply an acceleration to each generated circle (different in each one).
To apply the acceleration must indicate the indices of the segments of the circle, but when generating it programmatically I do not have them and they are not constant because in each execution the number of circles is changed, how can I obtain those indexes? Is there another solution?
The example code of the loop that generates the circles and tries to apply the acceleration is the following:
// LOOP (N = input value)
for (int i = 0; i < N; ++i) {
  // BUILD CIRCLE i
  String tag = "cloop"+(i+1);
  String pos = "aCol-d/2-d*"+i; // VERTICAL POSITION
  model.component("comp1").geom("geom1").create(tag, "Circle");
  model.component("comp1").geom("geom1").feature(tag).set("pos", new String[]{"0", pos});
  model.component("comp1").geom("geom1").feature(tag).set("r", "a/2");
  // ADD TO ACUMMULATIVE SELECTION FOR DIFFERENCE AFTER THE LOOP
  model.component("comp1").geom("geom1").feature(tag).set("contributeto", "csel1");
 // GET INDEX
  int[] idx = Unknown(tag); // ??????
  // ACCELERATION
 String atag = "naccloop"+(i+1);
 model.component("comp1").physics("acpr").create(atag, "NormalAcceleration", 1);
 model.component("comp1").physics("acpr").feature(atag).set("nacc", "exp(iniDist*"+i+"/c0 * j*2*pi*frecMax)"); // ACCELERATION VALUE i
 model.component("comp1").physics("acpr").feature(atag).selection().set(idx); // APPLY ACCEL
Thanks!
1 Reply Last Post 18.03.2019, 03:10 GMT-4
Posted: 7 years ago 18.03.2019, 03:10 GMT-4
Solved: I have created a cumulative selection in each iteration, I assign the current circle to the cumulative selection and I apply the physics.
  // Circle i
  // New cumulative selection i with one circle i
  model.component("comp1").geom("geom1").selection().create(tag+"sel", "CumulativeSelection");
  model.component("comp1").geom("geom1").feature(tag).set("contributeto", tag+"sel"); // one per circle
  // Apply physic to cumulative selection i
model.component("comp1").physics("acpr").feature(atag).selection().named("geom1_"+tag+"sel"+"_bnd");
Solved: I have created a cumulative selection in each iteration, I assign the current circle to the cumulative selection and I apply the physics. for (int i = 0; i < N; ++i) { // Circle i String tag = "cloop"+(i+1); String pos = "aCol-d/2-d*"+i; model.component("comp1").geom("geom1").create(tag, "Circle"); model.component("comp1").geom("geom1").feature(tag).set("pos", new String[]{"0", pos}); model.component("comp1").geom("geom1").feature(tag).set("r", "a/2"); // New cumulative selection i with one circle i model.component("comp1").geom("geom1").selection().create(tag+"sel", "CumulativeSelection"); model.component("comp1").geom("geom1").feature(tag).set("contributeto", tag+"sel"); // one per circle // Apply physic to cumulative selection i String atag = "naccloop"+(i+1); model.component("comp1").physics("acpr").create(atag, "NormalAcceleration", 1); model.component("comp1").physics("acpr").feature(atag).set("nacc", "exp(iniDist*"+i+"/c0 * j*2*pi*frecMax)"); model.component("comp1").physics("acpr").feature(atag).selection().named("geom1_"+tag+"sel"+"_bnd"); }
