Parameter or frequency sweep for local or global variables
Posted 28.11.2011, 16:53 GMT-5 Low-Frequency Electromagnetics, Materials, Parameters, Variables, & Functions, Results & Visualization Version 4.2 1 Reply
How can I correctly define and then plot my local variables that depend on frequency, following a frequency domain study (frequency sweep)?
I am using AC/DC module for a simple AC electrokinetics problem. My variable is a vector of force that depends on the electric field at a point, and frequency-dependent effective polarisation, alpha. Effective polarisation is in turn dependent on complex permittivity of the two materials that make the structure.
I defined the complex permittivities (eps_1 and eps_2) as parameters that depend on another parameter, frequency 'freq'. Alpha is a local variable given as an expression of the eps_1 and eps_2. Force is another vector variable whose X and Y components are given as expressions in alpha, Ex.norm, and Ey.norm.
Q1. I am unable to plot alpha(freq) from a frequency domain study, frequency sweep. I therefore don't trust my results for force. How could I verify the values of eps_1/2, and alpha for different frequencies? or plot them against frequency?
Q2. How can I ensure the values of the parameters specified are indeed changed according to the frequency sweep settings? Should I be defining the frequency-dependent parameters and variables differently?
Many thanks!
Many thanks!
1 Reply Last Post 29.11.2011, 01:31 GMT-5
