Problem specifying GaAs piezoelectric axes
Hi all! I am having trouble trying to simulate a 2D model of a GaAs SAW resonator. I've built my 2D model using the guidelines form the Comsol tutorial "SAW Gas Sensor", which simulates a unitary cell of a LiNbO3 SAW structure using appropriate boundary periodic conditions. The LiNbO3 model seems to work fine, and I obtain resonant and antiresonat eigenmodes at 927.8MHz and 940.66MHz (see attached model).
As a next step towards what I really need to analyze, I need to change the substrate to GaAs. However, I am not able to tell Comsol which crystal orientation it should take into account (I need to simulate a substrate normal to the <001> diretion and wave propagation in the (110) direction). Obviously, if I only change the material of the substrate in my LiNbO3 model, I get very different resonances and odd behavior (see attached model). I am almost sure the problem is the orientation of the model axes with respect to the crystal planes of the substrate, but I have no idea of that is the convention used by Comsol to map its xyz axes to the crystal directions.
I have tried to decipher Comsol's mapping by using 3D models and rotating them along various directions, but still had no luck; without knowing how Comsol interprets the axes of my drawn model (or how to change the way it does), I am just getting nonsense results!
Thanks in advance for any help!
Cheers,
Jorge.
0 Replies Last Post 02.05.2012, 05:29 MESZ
Hello Jorge
