Releasing a particle at arbitrary point of the inlet surface
Posted 31.05.2012, 04:52 GMT-4 Charged Particle Tracing, Fluid & Heat, Computational Fluid Dynamics (CFD), Particle Tracing for Fluid Flow Version 4.2a, Version 4.4 2 Replies
I'm simulating a laminar fluid flow through a channel with structures on the bottom. When I use particle tracing module the release options are 'mesh based', 'density' and 'projected plane grid'.
I'd like to know if there is a possibility to specify a single point of release at the inlet, so something like 'a start point controlled' release.
Thank you very much for your help!
Hello Izidor Sabotin
