17.07.2012, 11:25 MESZ
You need to define a step function and use it to multiply the inlet velocity so that the velocity goes from 0 to some value during the computation otherwise it will never manage to find correct initial values.
Cheers
Cheers
21.07.2012, 03:15 MESZ
Thank you very much. I tried it out and it worked. Seems the inlet condition was indeed too steep for the software to handle. I smoothened it out with a step function as you suggested and now the simulation runs on transient mode.
One more thing, since the simulations are taking a lot of time to execute, is there any way I can limit the number of iterations or run-time for which the simulation will give me a set of results? I know I can limit the number of iterations or tolerance at the 'segregated step' in the solver node, but is there any other way to do that?
Thanks again.
Thanks again.
21.07.2012, 10:14 MESZ
have you tried to run first a stationary solver case and then a transient. In this way you get really a good initial condition and your transent analysis will run smoother. Sometimes its better to start from a stationary high speed case and lower the inlet flow, than starting from "0", but you can also start from 10% or 50% of nominal inlet speed, in stationary, and then ramp up with a smooth step to 100% or whatever oscillatory conditions you want.
One thing if you start with a too slow flow, you are not really in a turbulent case, that might be an issue for your convergence
But, turbulent transient flow is something one mostly do on a cluster ;)
30.08.2012, 21:06 MESZ
I have the same problem here while i am simulating flow through fixed bed reactor,porous media, my problem is i tried
multiplying the inlet velocity with "step1" but it says "unknown variable step1".
what should i do in defining the etep funcation? i just used the default
location 0
from 0
To 1
then i simply multiply it with inlet velocity profile but it displays the above error
regards
location 0
from 0
To 1
regards
