Joule Heating- 3D Rectangular Bar
I have 3D model of a rectangular Copper bar with 3 rods attached to it. These 3 rods provide electric energy to heat the rod. I am not sure what is incorrect with the case set-up, asI have run a very similar case set-up in a different modeling code, and I get the error 'Unable to solve for T'. Ideally I would like to include Real and Imaginary components of Amps (as a current density input).
Any suggestions will be appreciated. Thanks!
3 Replies Last Post 20.12.2012, 19:46 MEZ
Posted: 1 decade ago 20.12.2012, 08:21 MEZ
this is because you have certainly played with your model and added and deleted a few times some physics, therefore your current physics is solving for "T2" and not "T". When you select several physics with the same dependent variable COMSOL renames then T2, T3 ...
Then for some reason the Results node were kept, so you have two referring to T and not T2. The error message comes from the Results, you case solves OK, see the last Temperature (JH) node
Hi this is because you have certainly played with your model and added and deleted a few times some physics, therefore your current physics is solving for "T2" and not "T". When you select several physics with the same dependent variable COMSOL renames then T2, T3 ... Then for some reason the Results node were kept, so you have two referring to T and not T2. The error message comes from the Results, you case solves OK, see the last Temperature (JH) node -- Good luck Ivar
Posted: 1 decade ago 20.12.2012, 13:55 MEZ
You are right. I did play around with the case a few times- I initially had fluid flow and HT case, to which I removed the fluid flow and did a pure Joule heating case (now I intend to add the flow inside the larger rectangular bar.)
I did not know that Comsol renames the temperatures in this manner- I will watch out for it in the future. Thanks for your help!
You are right. I did play around with the case a few times- I initially had fluid flow and HT case, to which I removed the fluid flow and did a pure Joule heating case (now I intend to add the flow inside the larger rectangular bar.) I did not know that Comsol renames the temperatures in this manner- I will watch out for it in the future. Thanks for your help!
Posted: 1 decade ago 20.12.2012, 19:46 MEZ
Its worth to check regularly the dependent varaibles and the equations for all physics, open the tabs (see preferences)
Hi Its worth to check regularly the dependent varaibles and the equations for all physics, open the tabs (see preferences) -- Good luck Ivar
