New to COMSOL. Help with structural analysis.
Hey guys, I have a 2'' hollow tube that is fixed at one end and has a point load at the other end. (think cantilever)
What I need is this:
I need the radius of curvature to be 3'', so I need to know what force to apply to the end of the tube. How would I go about doing this? Please note that currently I am using a 2'' piece of tube, but the length may vary. Not sure if it matters or not.
Any help is appreciated thanks.
4 Replies Last Post 08.01.2013, 06:59 MEZ
Posted: 1 decade ago 05.01.2013, 11:21 MEZ
If you have a tube, it's not only the diameter but also wall thicknes that should be considered, in addition to the length and the aterial parameters.
If you apply a "point" load you will get singularties, apply rather a Boundry load (surface for 3D, line for 2D but a tube is difficult to represent in 2D ;) or a Point in 1D.
Then if you want a radius of curvature you should rather apply a moment at the end and not a force, a force does not really give a regular radius of curvature.
Finally you need to define the "radius of curvature" there are some interesting threads on the FOURM try a search, somewhere one of the COMSOL employees have give a model to extract the radius of curvature for small and (?) lage deformations.
Once yo have the Radius you can define the moment (or force) as a global variable driven by the expression
(Calculated_Radius - Desire_Rradius)^2
Hi If you have a tube, it's not only the diameter but also wall thicknes that should be considered, in addition to the length and the aterial parameters. If you apply a "point" load you will get singularties, apply rather a Boundry load (surface for 3D, line for 2D but a tube is difficult to represent in 2D ;) or a Point in 1D. Then if you want a radius of curvature you should rather apply a moment at the end and not a force, a force does not really give a regular radius of curvature. Finally you need to define the "radius of curvature" there are some interesting threads on the FOURM try a search, somewhere one of the COMSOL employees have give a model to extract the radius of curvature for small and (?) lage deformations. Once yo have the Radius you can define the moment (or force) as a global variable driven by the expression (Calculated_Radius - Desire_Rradius)^2 -- Good luck Ivar
Posted: 1 decade ago 07.01.2013, 15:08 MEZ
Hi David,
I suggest you apply a moment not a point force as Ivar suggested. As an initial estimate based on beam theory the radius of curvature due to an applied moment = E*I/M.
Nagi Elabbasi
Veryst Engineering
Hi David, I suggest you apply a moment not a point force as Ivar suggested. As an initial estimate based on beam theory the radius of curvature due to an applied moment = E*I/M. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 07.01.2013, 21:34 MEZ
I think I managed it, but I do have a question.
In my pipe, after running the analysis, and graphing the Von Mises stresses on the entire pipe, is there anyway to cut half the pipe off so I can see the stresses on the inside of the pipe?
Thanks.
I think I managed it, but I do have a question. In my pipe, after running the analysis, and graphing the Von Mises stresses on the entire pipe, is there anyway to cut half the pipe off so I can see the stresses on the inside of the pipe? Thanks.
Posted: 1 decade ago 08.01.2013, 06:59 MEZ
Check the Results - Data set - Right-click - cut plane nodes and related help/doc
Hi Check the Results - Data set - Right-click - cut plane nodes and related help/doc -- Good luck Ivar
