Geometry present or not depending on a parameter
Posted 08.02.2013, 11:44 GMT-5 Geometry Version 4.3a 1 Reply
Hi!
I am trying to create a geometry that will have certain elements appear or disappear depending on a variable. For example: I have a variable "var1" that can take the values of 1 or 2. I have a geometry that hast a plate with a hole in the middle (in 2D, so it would basically look like a rectangle with a circle in the middle). I want to be able to have COMSOL build the geometry with the circle if I input 1 for "var1" and to build the geometry with just the rectangle is I input 2 for "var1"
Thank you very much for your help.
Francesco
Francesco
1 Reply Last Post 08.02.2013, 15:17 GMT-5
