2 sets of PDE equations with same variable
Dear all,
I have a Comsol model in which I have two almost identical sets of general PDE equations. This is because i first solve them with a stationary solver to find stable initial conditions and then introduce the time dependent parts and solve it with a time dependent solver. This way i avoid rapid changes in the first steps and get a more accurate result and a more stable solver.
I use the same depend variables in the two sets of equations so i can directly transfer the solution from the stationary solver to the initial conditions for the time dependent. However i get an error from the reset history command that says "Inconsistent dependable variable decleration. Previous unit: m^-2*m. Unit: m^-1*m."
Due to the answers given in this thread: www.comsol.com/community/forums/general/thread/12320/ I tried to rebuild the model from scratch, only to find I cannot add 2 sets of PDE equations with the same variable. I have to make them with different variables and then change the variable afterwards. This is what courses the reset history error. Apart from this one error the program seems to be working fine but now I'm uncertain if this is actually the wrong way to use the two different solvers since Comsol won't make two sets with the same variable from the start? I can't use the same equations for the steady state and the time dependent since the steady state solver can't handle time dependent functions needed in the time solver.
I have attached the program if anyone want to take a closer look.
Thank you in advance for your time
Mathias Christensen
1 Reply Last Post 28.03.2013, 21:53 MEZ
Posted: 1 decade ago 28.03.2013, 21:53 MEZ
often you can get around the missing definition of t=0 for a stationary solver, just preceding a time dependent one, by adding in the root Parameter a dummy t=0 and then arrange that your BC values at t=0 are those of the steady state, then you can use the same PDE's, run first a stationary solver, store, use the results as the initial values for a time dependent solver and have all under one "study node" to be initiated and solved in one click ;)
Hi often you can get around the missing definition of t=0 for a stationary solver, just preceding a time dependent one, by adding in the root Parameter a dummy t=0 and then arrange that your BC values at t=0 are those of the steady state, then you can use the same PDE's, run first a stationary solver, store, use the results as the initial values for a time dependent solver and have all under one "study node" to be initiated and solved in one click ;) -- Good luck Ivar
