How to Select the Appropriate Materials from the COMSOL Material Library for Photonics and Liquid Crystal Simulations at 1550 nm?
Dear COMSOL Community,
I am currently pursuing my Ph.D. research in the field of Photonics and Liquid Crystal (LC)-based devices using COMSOL Multiphysics 6.4.
For my simulations, I need to use the following materials:
  1. Silicon (Si)
  2. Silicon Dioxide (SiO₂)
  3. Gold (Au)
  4. E7 Liquid Crystal
  5. Silicon Nitride (Si₃N₄) and so on
My operating wavelength is 1550 nm.
When I use the Add Material option in COMSOL Multiphysics 6.4, I find multiple entries with the same or similar material names. I am unsure which specific material entry I should select for my photonics simulations.
I would appreciate guidance on the following questions:
When multiple entries are available for the same material in the COMSOL Material Library, how can I identify and select the most appropriate one?
Which material properties should I verify before selecting a material for optical simulations at 1550 nm (e.g., refractive index, extinction coefficient, relative permittivity, and wavelength-dependent properties)?
For Silicon, Silicon Dioxide, Gold, and Silicon Nitride, which material data or material models are recommended for photonics applications at 1550 nm?
For E7 liquid crystal, how can I select or define the appropriate anisotropic optical properties, particularly the ordinary refractive index (nₒ), extraordinary refractive index (nₑ), and director orientation along the X-axis or Y-axis?
If the required optical properties are not available in the built-in COMSOL Material Library, should I create custom materials using experimentally reported or literature-based optical constants?
My main objective is to ensure that I select the correct material properties for accurate electromagnetic wave propagation and photonic device simulations at 1550 nm.
I would be grateful for any suggestions, recommendations, or practical examples from experienced COMSOL users.
Thank you.
2 Replies Last Post 18.11.2026, 16:50 GMT-6
Diotima National University of Singapore/Mechanical Engineering
Posted: 2 days ago 17.11.2026, 04:37 GMT-6
Dear Rajasekhar,
In my opinion, you could build the entire physics first, and create an blank material so you know what parameter is needed for your model. After this, I think you can either find appropriate material by searching through literature, or just simply pick the material that has the closest material property to your experiment or working condition set up. Hopefully my answer helps.
Yuyang Zhang
Superiora de inferioribus, inferiora de superioribus, prodigiorum operatio ex uno, quemadmodum omnia ex uno eodemque ducunt originem, una eademque consilii administratione.
Dear Rajasekhar, In my opinion, you could build the entire physics first, and create an blank material so you know what parameter is needed for your model. After this, I think you can either find appropriate material by searching through literature, or just simply pick the material that has the closest material property to your experiment or working condition set up. Hopefully my answer helps. Yuyang Zhang
Posted: 1 hour ago 18.11.2026, 16:50 GMT-6
I have found the default material models in COMSOL to be quite reliable (with the single exception of one case where one, but only one, of the SiO2 models had a wrong parameter. Long since corrected.)
If there are multiple models under different headings you will usually find they are very similar.
Part of the job of one doing modeling is to think carefully about the material parameters used and, where necessary, to verify and correct. It's a simple matter of renaming and saving a modified material. Not all materials need to be carefully thought about. Maybe a conductor model is not critical as long as it is highly conducting. But again it is your job to know.
In the case mentioned, the liquid crystal parameters AND model will probably be the most important but also the most difficult to pin down.
As far as CHOICE of materials is concerned- that is engineering, outside the scope of modeling.
I have found the default material models in COMSOL to be quite reliable (with the single exception of one case where one, but only one, of the SiO2 models had a wrong parameter. Long since corrected.) If there are multiple models under different headings you will usually find they are very similar. Part of the job of one doing modeling is to think carefully about the material parameters used and, where necessary, to verify and correct. It's a simple matter of renaming and saving a modified material. Not all materials need to be carefully thought about. Maybe a conductor model is not critical as long as it is highly conducting. But again it is your job to know. In the case mentioned, the liquid crystal parameters AND model will probably be the most important but also the most difficult to pin down. As far as CHOICE of materials is concerned- that is engineering, outside the scope of modeling.
Reply
