setting mass flow rate at inlet
Posted 14.06.2013, 22:53 MESZ Computational Fluid Dynamics (CFD) Version 4.3b 2 Replies
Model description
I have a 3D laminar air flow inside channel whose cross section is rectangle. for BC ,
1- the inlet , mass flow rate boundary is set (kg/s),
2- the outlet , zero pressure p=0 pa
3- the all other boundaries are symmetry.
My problem:
When I run it, I have a problem with convergence , then eventually failed to find the solution
Hello Ahmed Suleiman
