Edgar J. Kaiser
Certified Consultant
30.07.2013, 11:30 MESZ
I think you need either AC/DC or RF for this, depending on the relation of structural dimensions and wavelength.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
Cheers
Edgar
Edgar J. Kaiser
30.07.2013, 11:39 MESZ
Hello ysbordain (what's your name btw),
seems a sure thing to me this is possible in COMSOL. I am not familiar with the semiconductor module, but I guess you can solve for your inner device potentials and then you can use a coupling operater to map the electric potential at the device boundary to the out-of-device physics, which would be electrostatics. The electrostatics interface is part of the COMSOL main package, afaik. Thus, you would not need the AC/DC module.
Coupling physics isn't a beginner's job, though. So you will probably have to put some time and work in it...
Best regards
Eric
Best regards
Eric
30.07.2013, 11:53 MESZ
Cheers
Edgar
Edgar J. Kaiser
Hi Edgar,
in case of high frequency studies of course. I didn't consider that case.
Maybe the thread starter could clarify that point.
[QUOTE]
Cheers
Edgar
Edgar J. Kaiser
[/QUOTE]
Hi Edgar,
30.07.2013, 18:15 MESZ
For now, I am only looking at electrostatics. I want to sweep the bias on the device and see how that changes the fields outside of the device. I then want to make an array of these devices and do the same thing, looking at how the distance between them change the fields in the environment.
30.07.2013, 18:17 MESZ
Thank you for your reply, Eric.
Are there any tutorials available for coupling the physics?
Yemaya
Yemaya
04.12.2014, 02:14 MEZ
Hi ysbordain. did you have any success in solving fields outside the semiconductor device ?
