2 decades ago
01.06.2010, 11:42 MESZ
but whith such dimensional ratios 120mm:0.25um = 480'000:1 are you sure you cannot use rather thin surface effects, as what is happening in the tichkness requires typically several elements and then you restrain the horizontal size too, and you will end up with something like 3-5*480'000^2 items. That would require really a super computer, no ?
Furthermore you should check your "repair" tolerance, that by default is at 10um (in V3.5) when you work with small or thin geometries
Hope this helps
Hope this helps
15.03.2011, 16:56 MEZ
I'm having the same problem modelling a MEMS cantilever. I've tried adjusting the tolerance - no help. Earlier version of COMSOL did not have this error, and coped with my dimensions. Sugestions?
15.03.2011, 17:12 MEZ
I have made several "thin" features in V4 (as before in v3.5a), cannot remember any special trick, apart from the tolerance settings.
You have possibly the CAD versus COMSOL kernel option (but I believe that is for the "import", would ahve to check again, but I do not have access to COMSOl just now ;)
For me V4.1 is working as good if not better than v3.5a now, but it took me quite some time to find back all the buttons and tweaks ;)
15.03.2011, 17:17 MEZ
My dimensions are defined in geometry by two planes each 40mmx4mm. One is extruded below the workplane by 400um to form the substrate, the other needs to be extruded by 0.072um above the workplane to define the second layer. It is at this step (tolerance tried from 10^6 to 10^10) that I get the problem.
