2 decades ago
05.06.2010, 15:12 MESZ
when I see these two equations, I understand mainly 3 unknown and two equations, then no boundary value, so its no full BVP like that, I'm missing a third equations and/or some boundary conditions to be "Comsol applicant", no ?
Perhaps the hypothesis Omega = cte, that is d/dx(Omega) = 0 (o whatever dimension) could add an equation, still what to put on the borders ?
I assume that you are using COMSOL standard notation of generalise dependent variables u and v the "general displacements" in 1,2 or 3D (of general coordinates x,y,z) and Omega some kind of value independent of the spatial dimensions (but no eigenvalue, time harmonic development) ? and not u,v the x, respective y displacements
2 decades ago
07.06.2010, 13:36 MESZ
Hi Ivar,
Thank you for your answer,
This problem describes the dynamic of two oscillators coupled. I look the eigenmodes of this system. It is a system of two equations with two unknowns which depends on the pulsation w (A11(w)*u + A12(w)*v = 0 AND A21(w)*u+A22(w)*v=0). When the determinant of the system is different of zero, this system admits the trivial solution u = v = 0. When the determinant of this system is zero (which defines the possibles w, I mean the eigenfrequencies of my coupled-oscillator) then there are non-zero solutions. There are two equations and two unknowns and this problem is easily solved by hand ! I would like use COMSOL to solve it for me ... that means finding w why this sytem to non-zero solutions and for each w find u and v. Remark that this system is not of the form A*u=lamda*u but it is of the form A*u=0.
Best
Pierre
Hi Ivar,
Best
Pierre
2 decades ago
07.06.2010, 13:46 MESZ
you are two here trying something simular (see the other thread), again what puzzles me is that to have Comsol finding solutions, you must tell it which are (all) the variables to solve for, so all three Lambda, u,v must be defined as unknown, and then the corresponding equations bust be entered.
And as Lambda i not depending on x,y,z, (while COMSOL assumes all unknown are related, if not told othervise), and if I read you correctly, then this must also be "told" to COMSOL via an appropriate equation(s)
Have fun Comsoling
ivar
Have fun Comsoling
ivar
