Applying boundary stresses
Posted 14.06.2010, 02:42 GMT-4 1 Reply
Hi all,
I'm trying to simulate fluid flow and heat transfer of molten metal. Strong thermal gradients cause Marangoni boundary conditions on upper and lower surfaces of the domain. Due to convergence difficulties the idea was to ramp up the Marangoni boundary condition with an additional factor.
I'm not completely sure how to understand the COMSOL workflow in this point. Is it appropriate to use the parametric sweep with the conditions for the ramp factor with initial conditions set to "Solution"? There also exists the possibility to enable the "continuation" checkbox in the stationary tab in the study settings. The stationary tab in the solver sequence unfortunately comes without this checkbox.
Now I use a combination of both: continuation checkbox on and parameter defined in the first stationary tab under "study" and parametric sweep with the same parameter defined again. I guess this is not the way to do it??
Moreover there is no convergence yet for realistic Marangoni stress conditions, maybe because of wrong solver setup?
Thanks in advance!
Thanks in advance!
1 Reply Last Post 14.06.2010, 09:57 GMT-4
