Temperature below 0K
I have a (imho) simple problem:
3D instationary heat flux
rectangular solid (1x1x10)
subdomain condition: given Initial temperature T(x,t=0)=T0=0K
boundary conditions: no heat flux on 5 surfaces
given constant temperature on 1 surface (1x1): T(x=0,t)=100K
this problem can be solved analytically (as a 1D problem), but if I do this with comsol, I get an temperature profile, where in the temperature is sometimes below 0K! How can I treat this problem correctly with COMSOL? I think, the problem is the following:
T(x,t=0)<>T(x=0,t) on the surface, where the temperatur is 100K (incompatible inital and boundary conditions)
Should I attache the file?
I'm using version 3.5a
Thanks!
0 Replies Last Post 22.06.2010, 10:04 MESZ
Hello Kai Schmitt
