Global constraint
In the support knowledge Base Solution Number 1042 there is an example how to implement a Global constraint.
I just wanted to test this and created a 1-d convection and conduction model consisting out of one subdomain with the following boundaries:
Then I defined as described in the example under Options > Integration Coupling Variables > Boundary Variables the variable T_probe with the expression T (point 1 in the example).
Afterwords I defined the global equation Q_0: T_probe-320=0.
When I try to solve the problem the error 7111 Singular matrix appears.
What happens there?
Thanks for comments!
0 Replies Last Post 02.09.2009, 14:55 MESZ
Hello Oliver Ottinger
