Imposing some conditions on an area rather line
I work on Comsol 3.5a. I have a 2D axi-symmetric model. There is a circular pipe which goes into the page. There is a through-and-through hole across the pipe. I have assumed same volume flow rate on both the sides of the hole. Since the area of the holes are not same, I used different velocity condition on both the sides of the hole (to maintain same volume flow rate).
But to simulate more realistically, I would like to impose some volume flow rate to the pipe (circular region) and then let the simulation runs its course and reveal the exact volume flow rate coming out of the holes depending on the pressure conditions outside the hole. (rather than me assuming equal volume flow rates from both holes)
Can anyone suggest a method to impose volume flow rate as the boundary condition over a circular region (2D) ?
Thank you in advance
Aditya
1 Reply Last Post 10.07.2010, 19:53 MESZ
Posted: 1 decade ago 10.07.2010, 19:53 MESZ
I have problems visualising your case, often uploading an image with the COMSOL coordinates helps, uploading a full model is also possible, but one should not always distribute free any model like that, that depends what your are working on ;)
Hi I have problems visualising your case, often uploading an image with the COMSOL coordinates helps, uploading a full model is also possible, but one should not always distribute free any model like that, that depends what your are working on ;) Good luck Ivar
