Using Parametric Extrusion by combining different solutions.
Gerardo E. Villarreal-Garcia
I ran different studies in the same model, each one for a different range of temperatures. I would like to create a parametric extrusion 2D of a cross section for one temperature from each solution, but it seems that Parametric Extrusion 2D shows the data for each value of the parameter within the same data set.
I though I could use the data set "Join" to pick data from each solution at a specific temperature, (using the "explicit" option), but apparently that's not the correct way to do it. Is that even possible? Or should I just run a different study with the particular temperatures I want and use that data set to do the parametric extrusion?
Thanks!
Gerardo
PhD Student
Centre for Quantum Photonics
H.H. Wills Physics Laboratory
University of Bristol
Tyndall Avenue
Bristol
BS8 1TL, UK
Office 1.25
Email: g.villarreal@bristol.ac.uk
2 Replies Last Post 30.09.2015, 15:59 MESZ
Posted: 10 years ago 30.09.2015, 15:13 MESZ
Have you considered the 'withsol()' operator?
Henrik
Hi, Have you considered the 'withsol()' operator? Regards, Henrik
Posted: 10 years ago 30.09.2015, 15:59 MESZ
Thanks for the comment! I found a way to do it, I created a 3D Plot Group with different surfaces, and I applied a constant deformation for each one to create an spatial offset. I'm not sure if what you suggested is easier or equivalent.
Thanks!
Gerardo
PhD Student
Tyndall Avenue
Bristol
BS8 1TL, UK
Office 1.25
Hi, Thanks for the comment! I found a way to do it, I created a 3D Plot Group with different surfaces, and I applied a constant deformation for each one to create an spatial offset. I'm not sure if what you suggested is easier or equivalent. Thanks! Gerardo -- Gerardo E. Villarreal-Garcia PhD Student Centre for Quantum Photonics H.H. Wills Physics Laboratory University of Bristol Tyndall Avenue Bristol BS8 1TL, UK Office 1.25 Email: g.villarreal@bristol.ac.uk
