What does these error messgae mean?
When I solve a nonlinear, coulped model in paramteric solver, the following message apperas:
Error:
Failed to find a solution for the initial parameter:
No convergence, even when using the minimum damping factor.
Returned solution has not converged.
Would you like to guide me how should I do in the next step?
Thank you very much!!
2 Replies Last Post 27.09.2010, 09:24 GMT-4
Jean-Christophe Lavocat
Posted: 2 decades ago 27.09.2010, 08:46 GMT-4
For me it always happened when I put non physical conditions. Try to proof read your initial conditions and www.comsol.com/support/knowledgebase/905/
For me it always happened when I put non physical conditions. Try to proof read your initial conditions and http://www.comsol.com/support/knowledgebase/905/
Posted: 2 decades ago 27.09.2010, 09:24 GMT-4
it can also come from initial conditions that are too far away from the default "0", so sometimes ramping some large values, or just setting more realistic initial conditions might help.
But certanly, one should always recheck all BC with this message
Hi it can also come from initial conditions that are too far away from the default "0", so sometimes ramping some large values, or just setting more realistic initial conditions might help. But certanly, one should always recheck all BC with this message -- Good luck Ivar
