interpolation function
I would like to use a interpolation function as a boundary condition. I want to set a temperature distribution as boundary condition. The file that I´m using for the interpolation is the one I have gotten from other comsol program. It has the following structure:
% x y t
-0.2883498 -0.28064913 311.4114616733292
-0.2883498 -0.28532457 311.4367944630273
-0.28604147 -0.28298685 311.42340527424335
-0.2883498 -0.29 311.44533424076195
-0.28604147 -0.28766227 311.44045724511426
-0.28373313 -0.28532457 311.4258140327221
But I´m getting the following error:
Error: 6170
Failed to evaluate variable.
- Variable: temp
- Geometry: 1
- Boundary: 3
- Variable: T0_htgh
- Defined as: temp
- Expression: -T+T0_htgh
Somebody could help me with this problem? (I`m using the 3.5amodel)
Thanks in advance!
Ann
3 Replies Last Post 19.05.2011, 11:43 GMT-4
Hello Izaro LL
Posted: 1 decade ago 28.02.2011, 10:50 GMT-5
Hello, Ann:
Much time has passed since you sent your message. Nevertheless, if you are already interested in it, I think I can help you. Could you send the original model or at least a simplified version of it with your definitions, constants, functions and so on?
Jesus.
Hello, Ann: Much time has passed since you sent your message. Nevertheless, if you are already interested in it, I think I can help you. Could you send the original model or at least a simplified version of it with your definitions, constants, functions and so on? Jesus.
Posted: 1 decade ago 19.05.2011, 10:20 GMT-4
I have similar errors. I'm trying to use an interpolated function, Q1, as the input for a heat source, but Q1 is not recognized as a variable. How do I use an interpolated function as a user-defined input? I will send the model if it helps.
Thanks!
Briana
Hi, I have similar errors. I'm trying to use an interpolated function, Q1, as the input for a heat source, but Q1 is not recognized as a variable. How do I use an interpolated function as a user-defined input? I will send the model if it helps. Thanks! Briana
Posted: 1 decade ago 19.05.2011, 11:43 GMT-4
FYI- just figured it out my problem with help of Jinlan Huang:
"You need to give an argument to the function when you call it. The argument
could be either an explicit number (e.g., int1(1)) or a variable as long as
it is define. For example, you can use int1(x) or int1(y) if you select
"Use space coordinates as arguments" check box when you define the
function."
Thanks Jinlan
FYI- just figured it out my problem with help of Jinlan Huang: "You need to give an argument to the function when you call it. The argument could be either an explicit number (e.g., int1(1)) or a variable as long as it is define. For example, you can use int1(x) or int1(y) if you select "Use space coordinates as arguments" check box when you define the function." Thanks Jinlan
