Can not use Previous Solution in Comsol
Solution > Time-Dependent Solver > Previous solution
I use ODE and DAE to solve my issues. It's ok to store previous solution before I add Events under ODE and DAE interface.
Whenever I us Events, Comsol show a error message box:
" The following feature has encountered a problem:
Singular matrix.
There are 1 void equations (empty rows in matrix) for the variable comp1.hpp.
and similarly for the degrees of freedom (empty columns in matrix).
- Feature: Time-Dependent Solver 1 (sol1/t1) "
I was definitely confused about this.
Can somebody explain to me and help me with a solution ?
Much appreciated !
2 Replies Last Post 08.04.2016, 23:10 MESZ
Hello Phuong Nguyen
Posted: 9 years ago 08.04.2016, 15:02 MESZ
I'm having the same problem. Did you already find a solution?
Kind regards,
Steven
Hi, I'm having the same problem. Did you already find a solution? Kind regards, Steven
Posted: 9 years ago 08.04.2016, 23:10 MESZ
Can you send your model?
