COMSOLPIN photodiode example simulation (updated)
Posted 08.03.2016, 19:31 GMT-5 Low-Frequency Electromagnetics, Semiconductor Devices, Wave Optics, Studies & Solvers Version 5.0 3 Replies
Hi, i'm trying to do a photodiode simulation based on the gaas PIN diode example from comsol. In this example, the electromagnetic wave is excited from port1 and port 2 at the semiconductor boundary, with uniform electric field. I made a slight change to the example. Instead of exciting a uniform wave at port 1, now i'm exciting it with a Gaussian field distribution, i.e, Ez=exp(-(x/1000[nm])^2). I've also made some change to the meshing(which works fine if the excitation is uniform). However, i'm getting this error:
Attempt to evaluate negative power of zero.
- Function: ^
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.ewfd.normE@VDN${realdot@2}
- Defined as: (0.5*((realdot(comp1.ewfd.Ez,comp1.ewfd.Ez)+(realdot(comp1.ewfd.Ex,comp1.ewfd.Ex)+realdot(comp1.ewfd.Ey,comp1.ewfd.Ey)))^(-0.5)))
- Variable: comp1.semi.Enorm0_wo@VDN${realdot@2}
- Defined as: ((0.5*((realdot(comp1.ewfd.Ez,comp1.ewfd.Ez)+(realdot(comp1.ewfd.Ex,comp1.ewfd.Ex)+realdot(comp1.ewfd.Ey,comp1.ewfd.Ey)))^(-0.5))))
- Expression: d(((comp1.semi.Enorm0_wo*unit_m_cf)/unit_V_cf),{realdot@2})
anyone has any idea what might be the cause? Thanks a lot!
- Function: ^
3 Replies Last Post 22.02.2017, 01:49 GMT-5
