Adding an extra dimension to 1-D battery model
Sara Taslimi Taleghani
Hi all,
I am working on modeling and simulation of Li-ion battery. My model is pseudo-2-dimensional one. So I need an extra dimension to consider diffusion equation in solid phase of porous electrode in radial-direction while other equations are assumed in x-direction. I do not know how to do that. Please help me.
3 Replies Last Post 17.03.2016, 17:59 GMT-4
Posted: 10 years ago 17.03.2016, 08:05 GMT-4
Hello Sara,
I am by no means an expert in your field, but it sounds like what you are trying to do is very similar to how this model is implemented: www.comsol.com/model/packed-bed-reactor-238 .
I hope it helps.
Hello Sara, I am by no means an expert in your field, but it sounds like what you are trying to do is very similar to how this model is implemented: http://www.comsol.com/model/packed-bed-reactor-238 . I hope it helps. Best regards, Jeff
Posted: 10 years ago 17.03.2016, 16:07 GMT-4
Hi Jeff,
Thanks for your response. Is it possible for you to introduce me an expert in battery part of COMSOL?I do not know how to contact them.
Sara
Hi Jeff, Thanks for your response. Is it possible for you to introduce me an expert in battery part of COMSOL?I do not know how to contact them. Best regards, Sara
Posted: 10 years ago 17.03.2016, 17:59 GMT-4
You can contact COMSOL's Tech Support team via the web portal www.comsol.com/support or by email at support@comsol.com . Your question will be assigned to the first available expert in the topic area of your question.
You can contact COMSOL's Tech Support team via the web portal www.comsol.com/support or by email at support@comsol.com . Your question will be assigned to the first available expert in the topic area of your question. Best regards, Jeff
