How to export tables?
in comsol 4.0a I can´t find any solution how to export the data that is stored in a table? The only possibility seems to copy the table to the clipboard. But I want to have the data to be stored into a file. I´ve already tried to draw a table plot, and to add the plot data to a report, but if I export the data of the table plot into a file an "unexpected error" occurs.
Does anyone know a solution how to export the data of a table?
Daniel
5 Replies Last Post 23.12.2010, 08:04 MEZ
Posted: 1 decade ago 16.11.2010, 09:05 MEZ
Hello Daniel,
this has been fixed in version 4.1, which is currently being shipped to customers on subscription.
Niklas Rom
COMSOL
Daniel
Hello Daniel, this has been fixed in version 4.1, which is currently being shipped to customers on subscription. Niklas Rom COMSOL [QUOTE] Hi, in comsol 4.0a I can´t find any solution how to export the data that is stored in a table? The only possibility seems to copy the table to the clipboard. But I want to have the data to be stored into a file. I´ve already tried to draw a table plot, and to add the plot data to a report, but if I export the data of the table plot into a file an "unexpected error" occurs. Does anyone know a solution how to export the data of a table? Thanks, Daniel [/QUOTE]
Posted: 1 decade ago 16.11.2010, 10:07 MEZ
Hello Niklas,
thank you for this hint. But in the new version will I still have to export the table data out of a table plot or will there be another solution?
Will Comsol 4.1 be available as an update to Comsol 4.0a or do I need to buy this version?
Daniel
Hello Niklas, thank you for this hint. But in the new version will I still have to export the table data out of a table plot or will there be another solution? Will Comsol 4.1 be available as an update to Comsol 4.0a or do I need to buy this version? Thanks, Daniel
Posted: 1 decade ago 22.12.2010, 11:36 MEZ
Daniel, I have the same problem with you. Did you find the way out?
Thank you in advance.
Hi, Daniel, I have the same problem with you. Did you find the way out? Thank you in advance.
Posted: 1 decade ago 22.12.2010, 12:02 MEZ
in Comsol 4.1 there is a button near the "export table to clipboard" button to export a table into a txt-file.
Furthermore in Comsol 4.1 my workaround to automatically export table data with the subnode "Report" works. If you have added a table plot, it´s now possible to export the table plot data without getting an error message.
In Comsol 4.0a there seems to be no solution yet.
Daniel
Hi, in Comsol 4.1 there is a button near the "export table to clipboard" button to export a table into a txt-file. Furthermore in Comsol 4.1 my workaround to automatically export table data with the subnode "Report" works. If you have added a table plot, it´s now possible to export the table plot data without getting an error message. In Comsol 4.0a there seems to be no solution yet. Daniel
Posted: 1 decade ago 23.12.2010, 08:04 MEZ
Daniel, thank you for your reply.
Best wishes for you.
Hi, Daniel, thank you for your reply. Best wishes for you.
