9 years ago
09.06.2016, 09:19 MESZ
there are several ways, also depending if you have turned the geometrical non-linear on.
Here is a toy model, the parameter are set to no thermal expansion DT=0 but to add thermal effects you can change DT to 10[K].
But first understand the different settings I have added hereby, there are elements under Definitions, in the Derived values and the Plots
Unfortunately I have only V5.2
9 years ago
10.06.2016, 06:27 MESZ
thanks Ivar
i am using a version 5 and i can't open the file from version 5.2 . Am getting a error " model build with a different version of Comsol Multiphysics ". In my model i have not turned the geometrical non linear ON .
Is there any other way to measure the expansion measure ?
thanks Ivar
9 years ago
10.06.2016, 21:39 MESZ
Sorry to hear you cannot read my 5.2 file, I do neither not have any way to generate an older model and as there are quite some nodes in there, not obvious to explain all settings ...
I join the file saved as an ".m" matlab model file, perhaps you can manage to read that one
